TAGGED: ansys-explicit, blast-load, explicit, Explosion
April 26, 2023 at 9:37 pm
Denys Hryshkov
SubscriberHi, I found a bug (?), the model calculates normally and the explosion happens. But when I change for example the radius of my TNT cylinder, the reaction just does not happen, the time step goes in a strip (and no, the detonation point is where it should be, I changed it). Although for example the extrude of my TNT can be changed, everything works.
The same way it happened by accident and when changing other parameters.
Screenshots: 1-3 is a working file, 4-6 reduced the radius of TNT from 31.5 to 20mm
Pls help me. -
April 28, 2023 at 10:53 am
Ram Gopisetti
Ansys EmployeeHi, is the euler domain corrected to all bodies ? in second design change, is the detonation inside or whith in the proxy to the body ?,
cheers, ram
April 29, 2023 at 9:21 am
Denys Hryshkov
SubscriberThe detonation point is in the bottom-middle of the cylinder, and the Euler domain is calculated according to the height of the cylinder, i.e., changing the diameter of the explosive does not affect these two parameters.
3349
2471
1310
1018
