explicit dynamics (turning process)
    • Rajender22
      sir tell me the setup setting of turning process in explicit dynamics for thermal analysis ?/
      any one is working on turning process???
    • peteroznewman
      The setup for turning is very similar to cutting which is described in this discussion.
      Create a workpiece using an Explicit Material that has a material failure model in it.
      Create a tool that doesn't have a material failure model (unless you want the tool to fail).
      Rotate the workpiece and move the tool into the workpiece.
      If you have more questions, please provide a specific example with some geometry.
    • Rajender22
      i rotate workpiece by displacement command. for realistic condition im not able to rotate workpiece by angular velocity or velocity ,,, i want turning result on various RPM ... is there any video which contents all this commands .. pls send link
    • peteroznewman
      When you rotate by a displacement with an end time defined in the settings, that is a fixed velocity. If you want half the velocity, double the end time.
Viewing 3 reply threads
