November 16, 2020 at 10:39 am
andreamadonia
SubscriberGoodmorning,
I want simulate an assembly constitued by 3 circular coaxial tubes and obviously using extracted beams.
I tried to explode the beam assembly in spaceclaim, without any results; so I tried to explode the 3D before extracting beams obtaining then (in Mechanical) 3 offsetted extracted beams..
Anyone know how to explode extracted beams assembly?
Thanks.
November 19, 2020 at 2:53 pmAniket
Forum ModeratorI am sorry, but what do you mean by explode beams? do you want to temporarily move them just for visualization?nIf so isnt the solid beams visualization useful:nArrayIf you want to explode it Mechanical, please note that Mechanical does not explode when the mesh is displayed. Also, beam cross sections (representation) do not explode with the exploded view of the, although the line bodies do explode.nArrayn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnViewing 1 reply thread- The topic ‘Explode Beam assembly’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
