Export 3d array of fluent data
    • psayasith
      Hello,nIs there a way to export a 3d array of pressure from fluent? I'm trying to get an output with x, y and z coordinates and the pressure. I need this array for the whole volume of my model, not just at the surfaces. Thank youn
    • Keyur Kanade
      Please file - export - solution data - ASCII format. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • psayasith
      Please file - export - solution data - ASCII format. Regards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Communityhttps://forum.ansys.com/discussion/comment/105872#Comment_105872
      When I do this, I'm only able to export data from surfaces. I'm trying to get these data points for the volume inside my model. n
    • DrAmine
      It should be possible to write ASCII data from all cell zones: you do not need to select any boundary surface.n
Viewing 3 reply threads
