Export as CGNS in Parameter Study
    • fabiang
      Hello everybody,
      I have a question regarding the automatic usage of TUI commands during a parameter study with lots of design points.
      Is there a way to tell Fluent after convergence to export the data as a .cngs file of every design point?
      So how is it possible to use TUI commands every design point?
      file/export/cgns
      First, I figured that I could use an UDF in the Function Hooks, but I've read using TUI commands in UDFs is not possible.
      Best regards,
      Fabian
      You can use TUI commands with UDFs, it's a scheme call and not that well documented: I can't provide anything additional to the documentation.
      However, you may be better off just adding an execute command for export at a high number of iterations: all being well this will trigger once the model converges.
    • fabiang
      Thanks for the response. I did what you suggested (see screenshot below) however it doesnt seem like a tries to run the command if convergence is reached before the iterations specified in the execute commands window.
      If I run the command manually via console, everything is working fine.
      Do you see my mistake?
