April 5, 2022 at 9:25 am
H2020
SubscriberHi,
I have finished simulating with Maxwell and got some really beautiful colormaps. Because I want to compare the results with an algorithm to each other, i need the color maps with the same dimensions.
Is there a way to directly export the field overlay in Maxwell? I havent found such an option.
Best,
H2020
April 6, 2022 at 2:43 pmDeyu Li
Ansys Employeeyes you can export the field result on a defined grid in field calculator.
Select Input: quantity->(for example, B)
Output: Export -> Calculate grid points-> (define the grid)
OK
And it will create a file contains all the field data in that defined grid.
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
