September 16, 2021 at 11:50 pm
Rudraishwarya
SubscriberCan you please suggest how to export vias from hfss to fab friendly format. Fab house recommended excellon format for holes.gerber but how can I get it from hfss.
September 21, 2021 at 1:12 pmPraneeth
Please provide more information to help us serve you better.
Best regards.
September 21, 2021 at 7:26 pmRudraishwarya
SubscriberI want to create a gerber file from HFSS. I am exporting the HFSS in .gds and then importing it in ads and then exporting to .gbr. But I cannot create a N/C drill file from hfss.
September 22, 2021 at 1:59 pmPraneeth
Exporting into N/C drill format is available in HFSS 3D layout.
Please try importing your model into HFSS 3D layout and then you can create N/C drill file from there.
All the very best.
September 22, 2021 at 4:40 pmRudraishwarya
SubscriberThank you
September 22, 2021 at 6:18 pmRudraishwarya
SubscriberBut I have another confusion. I will export each layer in HFSS separately (also vias) in dxf format and import all layers in HFSS3D and export the combined model? In that case I will have to export in .gbr file, but that will not include N/C drill file. Also I see I cannot export in .ncd (N/C drill) format. It cannot be saved in any folder. Please help. Thanks!
February 3, 2022 at 2:38 pmclo_bo
SubscriberHi, Related to this question....
Is there a simple way to export the HFSS model copper layers to HFSS 3D for ultimate gerber export? Currently I am exporting each individual copper layer to dxf then reimporting into HFSS 3D to export as gerbers.
Viewing 6 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
594
