Preprocessing
Preprocessing
Export Geometry in WB / Edit exported geometry in WB
    • Doyoung Kim
      Hello, I am new to ANSYS.
      I am doing deflection analysis of beam. And I am trying to do multi-step static structural analysis.
      For example, I'm using cantilever beam of 10m with point force at free end. Then, I would like to use the deflected 10m beam and add another 5m (straight) to the left.
      I tried exporting deflected beam geometry, but it comes with mesh and when I edit geometry (add 5m), I cannot mesh entire structure.
      I clicked Model from B and right click geometry then export as ANSYS geometry file. But it comes with mesh, can I export without mesh?
      Or, does anyone know if I can edit geometry in B?
      I am trying to create geometry like this. But I cannot mesh this.
      Thank you in advance!
    • peteroznewman
      A simple way to do this is to draw two lines, one 10 m long and the other 5 m long off the end of the first line. You can fix the start node of the 10 m long line. There are many ways to connect the two lines together. Use Shared Topology in DesignModeler or SpaceClaim. Or do a Mesh Merge in Mechanical.
      In step 1, apply the displacement to the node at the 10 m vertex. The 5 m long extension will remain straight. Then you can do what you want in step 2.
      • Doyoung Kim
        @peteroznewman Thank you so much! Your suggestion works for my application!
