March 12, 2021 at 12:17 pm
Rajan_Mistry
SubscriberI am simulating a microwave resonator in HFSS using the driven modal solver with a fast frequency sweep. I have used the field calculator to calculate the mean electric field in a block of air just above the resonator. But this only calculates for a single frequency in the sweep. How can apply this to all frequencies in the sweep to export a plot of mean E vs frequency ?n -
March 12, 2021 at 4:20 pm
Praneeth
Ansys EmployeenAre you trying to evaluate the average field over the defined volume or you want average field over the frequency range?nKindly confirm.nBest Regards,n -
March 12, 2021 at 4:31 pm
Rajan_Mistry
SubscriberThanks for your reply.nI want to average the field over the defined volume (which I have done using the field calculator) and then plot this average field against frequency.n -
March 12, 2021 at 5:22 pm
Praneeth
Ansys EmployeeHi,nDid you try assigning an output variable for the desired quantity? Kindly look into HFSS Help document regarding the definition of output variable.nAll the very best.nBest Regards,n -
March 16, 2021 at 12:37 pm
Rajan_Mistry
SubscriberThat works now, thank younn
Viewing 4 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
