Preprocessing
Preprocessing
Export msh file
    • SF_7
      Good morning everybody,
      I encounter a very strange problem with the generation of .msh file. I have created a 2D mesh in ansys and exported it as .msh file without a problem, then i have modified the geometry and i have created a new mesh. When i try to export it, no error message occurs, but in the directory there is no .msh file.
      Any idea?
      Thank you for the help
    • Vishal Ganore
      Please check the format in which you are exporting the mesh. .meshdat (default first option to export) or .msh. Both are different.
    • SF_7
      Hi Vishal, i'm sure that the option .msh is selected. With the old geometry the file was correctely saved, with the new one nothing happens
    • Vishal Ganore
      Please try saving your updated project file and export under different directory.
    • SF_7
      I've tried also in this way but it doesn't work. I've solved the problem by delating the ansys workbench and creating a new one
Viewing 4 reply threads
