export node temperature using udf
    • jscsgh
      Hiya,
      I am modelling a transient case with two phases, and I would like to know the temperature development of the nodes in a certain thread. I used udf to export the coordinates of the wanted nodes successfully. However, I had some problems when I tried to export the temperature. I defined the field variable name using the following lines:
      char *what = "temperature";
      Node_Function_Values(d, what);
      And I tried to obtain the temperature value using NODE_VALUE(v). But it reports as follows when I tried to print the temperature value.
      Error: floating point exception
      Error Object: #f
      The fl process could not be started.
      What is the possible reason which would cause this?
      Is it possible that the
      field variable name that I am using is not right, since it is a multiphase case. How can I know the list of field variable names that I can use in the function Node_Function_Values(d, what); for a multiphase case.
      Many thanks for your time and wish to hear from you soon.
      Best regards
      Heng
      Depending on what you want to do with the data you may find the File>Export options to be better, node data can be written out every some time steps for analysis.
      Which multiphase model? Some use a phase domain, some calculate temperature at the mixture level.
      • jscsgh
        Hi Robert, many thanks for your reply, and appologies that I didn't respond to your answer asap (in the old forum, once I received a reply, I will receive an email...it seems that this feature is not available in the new forum).
        Regarding the export options, I will check that. But the idea is that I am planning to export the node temperature in a certain thread with specific sequencing every time step. That's the reason why I would like to use UDF to export, but it seems that the function Node_Function_Values(d,temperature) is not working for a multiphase model.
        In terms of the multiphase model, I am using VOF model and I would like to export the mixture temperature of the node each timestep.
        Again many thanks for your time, and if you have some idea on how to use Node_Function_Values(d,temperature) in a multiphase case, please do let me now. Cheers!
    • DrAmine
      ASCII Export should make the job.
      • jscsgh
        Dear Amine, many thanks for your reply. I have tried ASCII Export, but the result is that the node coordinate is listed in a random order. I am planning to export them in a required sequence and in a certain thread. That's the reason why I am using UDF. Do you know how I can use Node_Function_Values(d,temperature) in a VOF multiphase case. Many Thanks again!
      No worries, IT are still hunting gremlins, once they're all caught I think we'll have emails etc.
      Strictly Fluent uses cell values, so have a look at C_T(c,t)
Viewing 3 reply threads
