October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeHow can one export only the face of a solid in CAD format?
October 17, 2017 at 9:27 am
Arun
Ansys EmployeeThis is not directly possible, but user can create a surface from the face using Concept//Surfaces from Faces. And then suppress the solid and finally export the geometry. You should be able to delete the created surface and unsupress original solid.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2644
2110
1335
1112
461
