October 28, 2018 at 1:57 pm
yakubfam
SubscriberHi,
i am a newbie and am using AIM 19.2 now..
I wanted to export the report, but now in v19.2 I've found that the report is much more simplified than the previous versions.. The previous versions included the detailed equations and formulas if I remember correctly.. Is there any option to generate them in this latest version or should I go back to v17.2 or v18.2??
Yakub
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2600
2086
1317
1108
459
