July 30, 2019 at 5:37 pm
jordimarce
SubscriberHi, I need to write my frequency response results (deformation, velocity, phase, for example) in a text file. I can write thew array for each substep and include the frequency of each substep and the displacement in the freuqency range. But I did not find how to include the respective velocity or the phase in the array. (I include the code I am using, which works).
/post1
*set,last
*get,freq_count,active,,set,sbst
*dim,freq_array,ARRAY,freq_count,2
*do,ii,1,freq_count
SET,1,ii
*GET,temp_b,ACTIVE,0,SET,FREQ
freq_array(ii,1)=temp_b
cmsel,s,MY_KEYPOINT
*get,node_id,NODE,0,num,max
*get,displ,NODE,node_id,U,sum
freq_array(ii,2)=displ
*enddo
*cfopen,'myharmonic','txt'
*vwrite,'Freq','displ'
(A8,X,A8)
*vwrite,freq_array(1,1),freq_array(1,2)
(F6.0,X,F10.2)
*cfclos
July 31, 2019 at 5:29 am
jj77
SubscriberThe velocity is simple. Multiply displacements with frequency array and time it with 2*pi. That is because velocity is angular frequency times displacement.
For the phase have a look at plcplx commands and search for examples.
https://books.google.co.uk/books?id=o9K-q9G6pgIC&pg=PA99&lpg=PA99&dq=plcplx+and+/output+and+ansys&source=bl&ots=pSc04cIwgM&sig=ACfU3U3axpySQD2zFjgVJp3llMSRuSIcTA&hl=en&sa=X&ved=2ahUKEwjI9vO0ud7jAhWIUcAKHT1OBX4Q6AEwGHoECAkQAQ#v=onepage&q=plcplx%20and%20%2Foutput%20and%20ansys&f=false
2080
1299
1106
459
