Export the data from contours
    • Marius Carrier
      I have pressure contours over a plane and want to export the values of the pressure. How do I do that?
      Thanks for the Help!
    • Federico Alzamora Previtali
      You can export data via File > Export > Solution Data... then select the File Type, the Surfaces and Quantities that you wish to export.
