August 14, 2018 at 10:06 am
Christophe
SubscriberHello,
I work with ANSYSEM 19 on a project.
I want to export the direction and the values of B_vector in a region and for different time (I have made a transient simulation)
I can have the direction and the value in a region (with calculator field in field overlays) but just for one specific time.
How I can have this for many differents times.
Thank you for your answer
Christophe
August 14, 2018 at 11:25 am
Sandeep Medikonda
Ansys EmployeeChristophe, This post has been moved here so that your post might get faster help.
August 14, 2018 at 2:53 pm
mgardner
SubscriberIn order to export the field quantities at each time step, you have to make it save fields at each time step. To do this right click on your analysis setup, select properties, click on the Save Fields tab, and enter the times at which you want to save fields.
August 16, 2018 at 7:30 am
Christophe
SubscriberHello,
Thank you for your answer. I do already that to see my results with an animation. But I need the vector field to work with matlab.
I don't know in which file, vector fields are automatically save. That's why I try to export them.
August 17, 2018 at 8:32 am
Christophe
SubscriberHello,
I have made the automation of the calculator of the B_vector with a script in python in the Iron Python Command windows
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1327
1110
461
