March 5, 2021 at 5:07 pm
charlietran
SubscriberHi guys!nI need to run a structural analysis of 3D wing using the pressure distribution on wing surface, calculated by Fluent. My question is: How to export the pressure distribution? Should I use relative or absolute pressure for structural analysis? nPs: I know that the problem may be easily resolve with one way FSI, connecting Fluent and Mechanical component together. But for now I don't have access to Fluent analysis system. Therefore I must use the exported pressure file and import into Mechanical through External Data component.n -
March 5, 2021 at 7:43 pm
YasserSelima
SubscriberFile>write>profile ... or file>export>profile if you are using workbench ... But I am not sure how to load it in mechanicaln -
YasserSelima
SubscriberUse total relative pressure.n -
March 6, 2021 at 1:32 am
charlietran
SubscribernCan I use the exported relative pressure directly or need to modify it?n -
March 6, 2021 at 1:41 am
YasserSelima
SubscriberIf the coordinates are the same, you don't need to modify it. You might need to modify the location if the structure coordinate is different. n
Viewing 4 reply threads
Trending discussions
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
