February 18, 2021 at 8:03 am
alimuradpasha
SubscriberHi,
I would like to export the heat flow over an area as a PROFILE from a steady state 3D simulation.
I load this Profile into another steady state 3D simulation. I would like to multiply the values ??for the heat flow from the PROFILE using a scalar. For this I would like to create an expression that contains the values ??of the profile. In the Ansys help page you can see that the profile can be used when writing the expression.
On the image you can see that, I don't have this tab.
Does anyone have an idea how to solve it?
February 18, 2021 at 12:11 pmRob
Ansys EmployeeCheck Section 5.2.5, did you load a profile? nFebruary 18, 2021 at 12:35 pmalimuradpasha
SubscriberYes i already loaded the profile and I can use the profile for boundary conditions. But for defining an expression it isn?t able to choose the profile, like I described before.nFebruary 18, 2021 at 1:35 pmRob
Ansys EmployeeAnd you're using 2021R1?nFebruary 18, 2021 at 2:15 pmalimuradpasha
SubscriberI am using 2020 R2.nFebruary 18, 2021 at 3:22 pmRob
Ansys EmployeeYou might want to try again in 2021R1: the manual doesn't have a section for Profiles in Expressions in 2020R2. nFebruary 19, 2021 at 7:32 amalimuradpasha
SubscriberThanks! The problem is solved by using ANSYS 2021 R1.nnBest regardsnViewing 6 reply threads- You must be logged in to reply to this topic.
5454
3419
2473
1310
1022
