Exporting ANSYS Results for visualization in Virtual Reality
    • jtalier
      Hi there,
      I have searched around for a way to export an ANSYS simulation for easy viewing in virtual reality and have not found anything. What I am trying to do is export a results mesh (deformed), with an applied color gradient and then import that into Unreal Engine. Right now I can only get the deformed mesh imported with no color. Obviously stl files do not support color by default, but apparently it is possible (https://en.wikipedia.org/wiki/STL_(file_format)).
      Currently what I am thinking will be the easiest solution is to export all the nodes in a certain stress range say 0psi to 10,000psi as an stl file and then color that entire stl in Unreal. I would repeat this for all the other ranges. This would be quite tedious obviously.
      The other solution would be to take in the raw results output file and write a script to easily import that in another file with the correct color gradients applied.
      If anyone has any ideas or solutions to this problem I would love to hear it. Being able to export ANSYS results into VR would certainly be an interesting project!
      In Fluent we can also export VRML (coloured stl), not sure whether CFD Post and Mechanical support those exports without looking: let us know what you find when you try.
      • Osama Maddani
        how to export fluent pathlines as VRML? only the mesh is exported when I tried but not the velocity pathlines
