Exporting colormap data
    • jaina
       I have completed a thermal simulation in CFX, and would like to export temperature data on a planar surface as a CSV file, in order to be able to analyze/plot in a separate software. I defined a point cloud in each direction on the surface, but can not figure out how to export the data on the point cloud to a CSV file. I would be grateful if someone could point me in the correct direction.
      regards,
      A
    • RK
      Please refer to the following thread on the student community on extracting monitor data.
      https://studentcommunity.ansys.com/thread/when-extracting-monitoring-data-from-a-r/
      Rahul
    • jaina
       Rahul,
        Thanks for the pointers. However, the data I am looking for is not defined in the form of a monitor. I am looking to plot the temperature contour on a 2D surface, for which I need to define in CFX-Post multiple points (a point cloud) on the surface, followed by exporting the data on the point cloud. I have been able to define the point cloud, but following that, I can not figure out how to export the temperature data on that point cloud.
       Will the commands given in the link you shared do this for me? Is there a GUI-driven approach instead of command line?
      regards,
      A
    • jaina
      Hello, I was able to figure it out. Thanks again for your help.
      regards,
      A
    • Keyur Kanade
      Glad that the issue is resolved. Can you please mark this post as 'Is Solution' to help others on community.
      Keyur
Viewing 4 reply threads
