TAGGED: exporting, frequency-sweep, MODE-INTERCONNECT, python
February 1, 2022 at 11:32 pm
Arthaj
SubscriberHello all,
As the title suggests, I am trying to export the results of a MODE frequency sweep for INTERCONNECT using the Python API. I attempted
m.frequencysweep()
m.copydcard("frequencysweep","fs");
m.savedcard("data","fs")
but the output was unreadable by INTERCONNECT. What may I do instead?
February 2, 2022 at 4:54 pmArthaj
SubscriberHello all My bad, I forgot to check dispersion.
February 3, 2022 at 6:34 pmViewing 2 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
3930
2649
1861
1272
610
