3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Exporting from SpaceClaim
    • Richard Dooler
      Hi
      Why am I unable to save to any other format.  Previously I've been able to export to step, iges, stl etc.  Is it the Licence that I have?
    • Devendra Badgujar
      Forum Moderator
      Hello Richard Dooler
      It looks like you have a SpaceClaim Engineer license and not Subscription.
      There are two possibilities:
      1. When you first launch the SpaceClaim installer, there are two buttons. One is called SpaceClaim, and the other is called SpaceClaim Translators. If you did not run that 2nd option, try doing that. The most common reason for missing file type options is overlooking that translator's button in the install menu.
      2. Occasionally the link to the translators gets corrupted. You may need to go into the Windows Registry and delete the following keys:
      HKEY_CURRENT_USER > Software > SpaceClaim > LicenseReset > Reset
      HKEY_CURRENT_USER > Software > SpaceClaim > Primary > LicenseType
      (To get to the Windows Registry, type "regedit" into the Windows search bar, and open the Registry Editor)
      Let me know if this works for you. Thank you!
    • Richard Dooler
      Its a student edition as I  work for a university.  Still doesn't work?
      • Devendra Badgujar
        Forum Moderator
        Richard Dooler
        This Forum is meant for support for Discovery Commercial licenses.
        For Student licenses please post your queries on the Ansys Learning Forum. Our Engineers will help you through that channel.
        Regards.
