February 28, 2017 at 9:28 am
Nikita
Ansys EmployeeHow can one export only the face of a solid in CAD format?
March 21, 2017 at 10:28 am
Vishal Ganore
Ansys EmployeeThis is not directly possible, but user can create a surface from the face using Concept//Surfaces from Faces. And then suppress the solid and finally export the geometry. You should be able to delete the created surface and unsupress original solid.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
