September 27, 2018 at 12:36 am
Aleksandr Kiessling
SubscriberHey,
I built a simulation fora university project but am not able to export the results from Ansys AIM 19.1 to excel or any other type of file. I looked for a button, but I could not find one.
Can you help me?
Best Regards
Aleks
September 27, 2018 at 8:35 am
September 27, 2018 at 4:48 pm
Aleksandr Kiessling
Subscriberthanks, Rohith. Which version are you using?
i am downloading the 19.2 AIM student version right now. but does anyone know about a feature in 19.1? I can not believe that there is no feature to export data.
September 28, 2018 at 2:30 pm
raul.raghav
SubscriberFor the earlier versions of Ansys AIM, there is a beta feature to export the contour data to a csv file. Please refer to the following thread on how to use the beta feature:
https://forum.ansys.com/forums/topic/export-data-from-ansys-aim/
October 15, 2018 at 2:07 am
Aleksandr Kiessling
SubscriberHi, sorry for not getting back to you earlier. I was bussy with some internship applications.
I tried the solutions you proposed and with Ansys AIM 19.2, it worked.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1345
1118
461
