Exporting .sim file & Command for updating all design points
    • JesusER
      Hi all,
      Quick question, how can I export a simulation file (.sim file) after setting it up using Fluent? I need a simulation file to run it through a HPC cluster. Unless there is another command or file to do this job.
      Also, what command could I use to update all 'design points' which I set in the parameter set tool? This is to avoid running a single simulation or job for each design point...
      I run ANSYS 2020R1 and I use MobaXTerm for connection to the cluster.
      Thanks in advance,
      Jesus Esquivel Roman
Viewing 0 reply threads
