Exporting Stiffness matrix and mass matrix from ansys
    • Kavi Pradhap M
      Greetings of the Day!!
      I am trying to exprot stiffness matrix from modal anlysis, I have followed the following video still I am not able to export stiffness matrix.
      This the command I used:
      *DMAT,MatKD,D,IMPORT,FULL,file.full,STIFF
      *PRINT,MatKD,Kdense.matrix
      In the command file under solution tree. It shows the following.
      File status shows: File not found.
      video link :
      The file.full this file is missing in the analysis folder.
      How to rectify this?. Kindly guide to sort this out.
    • Rahul Kumbhar
      Hello Kavi,
      Go to Analysis Setting>> Analysis Data Management. Set the option 'Delete Unneeded Files' to 'No'. After this you need to clear generated data nad re-solve the Modal analysis.
    • Rahul Kumbhar
      Hi Kavi,
      Try solving using SMP mode. For SMP mode, you need to uncheck the 'Distributed' option.
