Ansys Products
Ansys Products
Exposing other versions of LS-DYna on Linux
    • Oleg Makarov
      Hello!
      According to LS-Dyna User Guide, it is possible to mention other .exe files of LS-Dyna solvers in lsdyna_solvers.xml. In Windows, this file is located at  C:\Users\CurrentUser>\AppData\Roaming\Ansys\231\ACTLSDYNA. After that another version will be available in LS-Dyna Workbench environment.
      I use Workbench on Linux, so is it possible to configure the same file in Linux? How can I do that and where it is located?
    • Ram Gopisetti
      Hi
      Can you check the app data equivalent directory in the LINUX
      cheers, ram
    • ANSYS_MMadore
      The equivalent location on Linux would be %HOME%\.ansys\231\ACTLSDYNA.
