July 6, 2020 at 8:45 pm
ducogaillard
SubscriberHi everybody,
I have a large, transient, fluid flow simulation with hundreds of time-steps (.dat files), in which the basic fluid flow field is solved.
I want to add in the species transport model in this simulation. The geometry has multiple inlets, the goal is to "color" fluid coming from one of the inlets. I do this by creating a material which is exactly the same as the bulk material, and having it come out of the selected inlet. This allows me to determine the amount of fluid coming from that inlet in any cell.
Because the two materials are identical, the species transport will have no effect on the flow field.
Is there a way to use the flow field, which is already calculated, to quickly calculate the concentration of this identical species throughout the geometry?
Proposition of a different method is also welcome.
July 7, 2020 at 4:56 am
DrAmine
Ansys Employeeyou can try enabling species model and run further. There are a couple of other ways but see if the mist simple one does work. -
July 7, 2020 at 10:52 am
ducogaillard
SubscriberHi Amine, thanks for your reply.
Unfortunately that wont work as I will have to re-run all the time steps that I have calculated. I'm really looking to edit the timesteps (.dat files) that I already have.
Kind regards,
Duco
July 7, 2020 at 11:38 am
DrAmine
Ansys EmployeeYou cannot edit the created dat files.
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2656
2120
1347
1118
461
