TAGGED: acoustics, act, act-extentions, hpc, jobs-in-cluster
May 18, 2022 at 9:09 am
v.vaniushkina-1
SubscriberHello
I am trying to run acoustic simulation on hpc in mt university and I am encounting two problems:
- I could not find any information on how to do meshing on cluster and it takes quite long on my own computer
- The ACT extention is needed. There is a folder with ACT files on cluster verion of ANSYS, however I don't know how to activate it . You can see on the attached screenshot the message I get
The way I run the job is following: runwb2 -B -F project.wbpj -R script.wbjn The script file: # encoding: utf-8 # 2019 R2 SetScriptVersion(Version="19.4.159") Update() Save(Overwrite=True)
May 19, 2022 at 3:28 pmRK
Ansys EmployeeHello,
May I know which software you are using for meshing? You can make use of parallel meshing if you are using Fluent meshing, in the volume generation process.
May 20, 2022 at 10:04 amv.vaniushkina-1
SubscriberHello
I am doing modal and harmonic acoustics analysis? so I don't think I use fluent meshing. I just do it from standart workbench interface
May 26, 2022 at 4:44 pmAniket
Ansys EmployeeDoes your cluster have Graphics output? If yes, meshing would be the same as what you would have on windows, but I am assuming you don't have graphics output for the cluster and need to run this in the batch, you can use the same way as you are using currently and as you update the system using script.wbjn mesh should be automatically created. In case it fails you should be able to save the project on the cluster and debug the mesh based on errors you receive.
LS-Dyna extension is not supported on Linux in case you are using it on Linux. If you are using Modal and Harmonic acoustics analysis, I don't think you need that extension.
-Aniket
Trending discussions- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- ANSYS Multi field 2-way FSI data coupling issue
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
3812
2607
1853
1244
600
