March 7, 2023 at 6:52 pm
March 22, 2023 at 12:44 pm
HDLI
Ansys EmployeeHello junaed.buet,
You could try "save data" to export duty cycle format, and then modify this saved file with your own data.
Fianlly, you can import your data with correct format. Thanks.
Howard
- Maxwell, HFSS or Q3D?
- Error
3826
2607
1853
1244
600
