February 28, 2018 at 9:40 pm
doatis
SubscriberIs there a way to create an enclosure and then use that for a fluid flow calculation? If I create an enclosure (Setup>Enclosure) that just creates a bounding box, it does not boolean-out the solid it encloses. If I create a fluid flow simulation, it doesn't let me select the enclosure (by default). If I enable enclosure selection, it still doesn't seem to operate correctly. Almost as if doing a fluid simulation requires the solution to create the fluid domain, rather than doing anything on my own ahead of time?
Basically, how do I manually create a fluid domain (internal or external) and use that for the fluid simulation?
March 1, 2018 at 9:42 am
Naresh Patre
Ansys EmployeeHello doatis
Discovery Live allows creation of enclosure which can be used later in simulation process. Please find attached a video which shows an enclosure created and then used in defining fluid flow simulation. On similar lines, you can first create internal fluid and then use it in fluid simulation.
If the method shown in attached video is not working at your end, can you send a test geometry for further investigation?
March 1, 2018 at 4:13 pm
doatis
SubscriberNaresh Patre - Thank you so much! That method works, not sure what I was doing wrong before. Chalk it up to user error. Thanks!
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Copy user settings to new release
- Can’t see license on online account
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- help online
- Python Script: graphical interface
- Unexpected graphics error
5454
3419
2473
1310
1022
