External pressure Cylinder buckling
    • OguzhanA
    • Ashish Khemka
      nnPlease see if the following link helps:nnnRegards,nAshish Khemkan
    • OguzhanA
      Hi! I have already reviewed this document. And you can see my result with stabilzation. n
    • HuiLiu
      Hi, could you take a look at this link from Help for limitations and best practice of using arclength method? What error/warning message did you encounter with the unconverged case? You might want to adjust the max/min arc radius multiplier using that arclen command. Also, is this a symmetric problem? If it is you can try take advantage of modeling only half/quarter of it for faster solve AND easier convergence.n
    • OguzhanA
      thanks for your comment you can see what I did below. Where exactly am I going wrong?nI added this commands. is it enough for arclength?nGeometry and BCnstabilization settings-offnShould I change the newton raphson setting ?nRegardsnOguzha
Viewing 4 reply threads
