Tagged: explicit-dynamics, export-result, plot-results
February 4, 2022 at 1:38 pm
muthul67
SubscriberHi, I would like to know is there a way to extract or export data from the energy summery plot.
Thank You
February 7, 2022 at 5:25 pmAshish Khemka
Please see if the following links help:
2.14.1. Solution Output (ansys.com)
How to predict the result by seeing the energy summary? ÔÇö Ansys Learning Forum
how to extract hourglass energy values in autodyn V19.2 ? ÔÇö Ansys Learning Forum
Regards Ashish Khemka
February 7, 2022 at 10:52 pmChris Quan
Ansys EmployeeFor Explicit Dynamics system, you can find the output of energy conservation and energy summary in the print file "admodel.prt". "admodel.prt" is located in the solver file folder - MECH.
For LS-DYNA system, you can find the output of energy conservation and energy summary in the ASCII output file "glstat". "glstat" is located in the solver file folder - MECH, too.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3670
2538
1749
1226
580
