Extract Nodal Forces and Nodal Moments
    • str35
      I'm trying to extract nodal forces and nodal moments using post-processing command.
      I tried PRESOL command like below:
      /POST1
      ! Start the post-processing process
      PRESOL,S,
      ! End the post-processing process
      /POST26
      But i got a warning message: "The geometry is not available.  The PRESOL command is ignored."
      How can i extract nodal forces/moments node by node ?
      Thank you.
    • Ashish Khemka
      Can you issue the SET command to select a relevant result and also issue ALLSEL, ALL to select everything?
      Ashish Khemka
