July 17, 2019 at 3:57 pm
Custal
SubscriberHi,
I'm wondering if it is possible to extract the data of a primitive shape such as it's position and dimensions using a command in IronPython which would return these values. I've had a look through the scripting guide but can't find anything on this. Alternatively is it possible to extract design variables instead?
July 18, 2019 at 8:35 am
Ansys EmployeeWhich tool are you looking at? Also what do you need/want to do with the data?
July 18, 2019 at 8:43 am
Custal
SubscriberI'm using Q3D at the moment but may be moving to HFSS in the future. I want a user to be able to define some locations and dimensions on a premade model which can than be extracted when the model is loaded using IronPython. IronPython will then use this data to adapt the model. I thought that perhaps the easiest way to do this would be for a user to draw a shape at the desired location with the desired dimensions which IronPython could then extract if possible.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3744
2573
1821
1236
596
