June 22, 2023 at 10:36 am
June 22, 2023 at 1:19 pm
Armin_A
SubscriberHi Joe,
Does the hole exist in your model before deformation or it is generated due to failure in the material? You can extract directional deformation along x, y, and z of the nodes located at the end of the arrows in your picture to obtain the current location of the nodes. Next, calculate the distance of the two nodes using d = ((x2 - x1)2 + (y2 - y1)2 + (z2 - z1)2)1/2
July 12, 2023 at 4:33 am
Tonmoy
SubscriberHi Joe,
- To measure the directional deformation of nodes in LS-Dyna follow these steps:
- Go to FEM>Element Tools>Measure on the top menu.
- Select Dist N2N as the type of measurement, which means distance between two nodes.
Choose the nodes you want to measure and hit plot. It’ll show the change of displacement between the selected nodes in time.
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7686
4476
2957
1435
1322
