extracting solution data in parametric report.
    • CORMAC JAMES MCCUMISKEY
      Hi all,
      So I know when I run a simulation I can click "extract solution data" and I get the full set of x,y,z coordinates and x,y,z velocities for every mesh cube. I also know how to set up a parametric study to iterate through multiple design cases. Can I extract solution data for each design case in the parametric report?
      Someone suggested that I use Journal files although I'm not sure where to start?
      Any help would be of great benefit to me,
      Thanks,
      Cormac.
    • Nilay Pedram
      To manage files (reading and writing project files) for your Parametric study - 40.10. Managing Files for Your Parametric Studies (ansys.com)
      To create and read Journal files - 5.6. Creating and Reading Journal Files (ansys.com)
      If you are not able to access the above link, please follow this forum discussion - How to access the ANSYS Online Help
      Hope this helps you. Thank you!
