May 11, 2023 at 3:51 pm
Saha
SubscriberIs there any way to monitor index profile of a material over time in a nonlinear pump-probe simulation in Lumerical FDTD ?
I want to simulate a pump-probe experiment, where the intense pump will propagate through a dispersive nonlinear material and induce a change in index (for example by effective third order nonlinearity) and I want to see this change in the material index over time.
I see there are separate index monitors and time monitors available in Lumerical. But is there a way to combine them here, or is there a way to do it with post processing? -
May 11, 2023 at 10:19 pm
Guilin Sun
Ansys EmployeeCurrently the time-related index cannot be output. You can file a feature request.
The index monitor is only for frequency-domain, which is frequency-dependent as expeted.
One way to get the time evolving index is from theory: calculate the induced index change by the nonlinear effects. You can record the time-dependent fields with a time monitor.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5268
3299
2469
