March 31, 2023 at 2:42 pm
Sushil Sharma
Subscriber1)- I am doing my thesis work in wind turbine blade fatigue analysis. I create a blade model with shell elements and assign materials and sectional properties in ansys workbench "ACP (pre)." Now I want to extract the geometrical information of the blade section (e.g., centroid, shear center, flexural center, Moment of inertia) in a longitudinal direction at a different blade length. Can I get such information in ansys workbench, where I have a complete model with sectional properties?
2)- can I extract a section of my model as a separate ansys file, with assigned materials properties (as shown in the attached figure)?
3)- If I got the above-mentioned point locations in my model, how can I define these points as remote points to assign calculated resultant forces as a remote force to these points?
Any clues or guidance you can give me will be beneficial to proceed further in my work.
Thank you
April 7, 2023 at 1:00 pm
Albra Albashir
Subscribersorry
April 13, 2023 at 10:00 am
Ashish Khemka
Ansys EmployeeHi Sushil,
I am not sure if you will get all the information in MEchanical. Try importing the model from ACP into Mechanical and then you get some of the required information. Please see if the following video is of help to you:
(149) What is Center of gravity & Centroid & How to find Center of Gravity in ANSYS - YouTube
Ashish Khemka
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5162
3275
2451
