Extraction of particles from a laser abaltion process
    • winterjo64576
      Hey,
      I have to run a simulation with the topic in the title.
      My biggest problem right now is how i could do a simple model which i can use to validate my simulation.
      Here a principal scheme:
    • Karthik R
      Administrator
      Hello Ablation is tricky to model where you will need to remove some surface material based on the laser temperature. Depending on your modeling objective, you can use different tools for this. What is the final objective of your simulation? Are you looking to understand just the flow? Or do you wish to model the ablation process?
      You could conceivably use the Moving Deforming Meshes in Ansys Fluent to study the recession rate on the ablation surface. Again, this is just a thought.
      Karthik
