September 12, 2019 at 3:25 pm
AgriCFD
SubscriberHi,
currently I do a transient calculation (k-epsilon) on a fast rotating (3000rpm) mower unit. I only simulate one rotor.
The Problem:
Simulation is running for a few time steps (approx. 5-30, depending on the initial flow field). The residuals are high but very evenly. Then Epsilon residual starts vibrating. Then, suddenly I get a floating Point exeption, with the residuals always being below 1e-01.
Console Output:
Divergence detected in AMG solver: epsilon
Error at host: floating point exception
Error at Node 0: floating point exception
I found an area of extremly high turbulence variables (turbulent intensity: >1500%). I think this is the problematic area, but I dont know what to do. Can someone help me out with this Problem.
I tried a lot of Things:
- created a better mesh ()
- enlarged the fluid domain around the mower (with smaller Domain I had backflow and high turbulent viscosity ratio)
- reduced the relaxation factors
Possibly interesting: I did the same calculation with a rotational Speed of 300rpm and the Simulation is running without Problems. But even in this case the turbulence in the problematic areas is extreme (turb. intensity > 200%). Is there a possible reason for this?
September 12, 2019 at 4:32 pm
DrAmine
Ansys EmployeeBetter mesh with low aspect ration, lower skewness and low cell volume change. I won't touch anything else before ameliorating the grid in the areas where you think that is related to that. Just have a look into the areas where you high TVR, locate them and check the values of the mesh metrics.
2688
2138
1355
1136
462
