March 4, 2022 at 8:58 am
Monta
SubscriberHello eveyone,
for modeling turbulent flow, it is recommended to consider an entrance length to get a fully developed turbulent flow. I did it so far in Design modeler or in SpaceClaim but I want to know if there is extrusion function or sthg like for example in STAR CCM+ where that does the same thing.
Regards
Monta
March 4, 2022 at 10:02 amKeyur Kanade
Ansys EmployeeYou can use TUI for that: mesh\modify-zones\extrude
You can also extrude in Fluent Meshing watertight workflow.
Please go through help manual for more details
Regards Keyur
March 4, 2022 at 1:35 pmMonta
Subscriberthanks for replying. I don't mean later in fluent. I mean in Ansys Meshing before loading the mesh to fluent.
Regards Monta
March 4, 2022 at 1:48 pmRob
Ansys EmployeeIt's an extra option once the volume mesh has been created. Right click on the "volume mesh" action in the workflow and it should be there. Note it's new in 2022R1 so whilst possible in earlier versions you'd need to interact with the mesh objects.
March 7, 2022 at 10:22 amMarch 7, 2022 at 3:35 pmRob
Ansys EmployeeNot in Ansys (Workbench) Meshing, that requires the geometry to be present. Fluent Meshing works with a facetted version of the geometry so suffers fewer constraints (but has other issues). You can extrude the face mesh in Fluent, but the function may only be available if you run on one node (it used to be a serial only feature).
Viewing 5 reply threads- You must be logged in to reply to this topic.
2620
2098
1323
1110
461
