November 6, 2023 at 8:46 pm
November 7, 2023 at 6:11 am
Charudatta Bandgar
Forum ModeratorDamian,
If your curves are continous closed loop, you should be able to use the fill option to fill the surface. Are you facing any issues? If the fill option is not working, it is possible that it is not closed. Once it is filled to create a surface, it can be extruded using pull feature.
Charudatta
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8762
4658
3151
1678
1456
