July 11, 2019 at 1:11 am
July 11, 2019 at 2:07 am
SubscriberTry exporting a STEP file from Creo instead of IGES.
I don't know if there is a facet quality setting in Creo, but if there is, try turning that up.
You can try SpaceClaim, which has some very easy to use geometry repair tools.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3930
2649
1869
1272
610
