September 10, 2018 at 8:15 pm
mashimaro_star
SubscriberThis is recently happened. When I reopen a Fluent case (which I can open using tecplot without any problem), Fluent gives me error:
"Face ID 3790811 out of declared range (1<=id<=3681795)".
I use double precision and 32 processors to calculate the case. The mesh was generated using Fluent Meshing.
Is there any specific way to solve this problem?
September 11, 2018 at 2:09 am
Keyur Kanade
Ansys EmployeeHi,
Can you open that file in Fluent Meshing?
Once open in Fluent Meshing, can you please check the mesh using Mesh --> Check.
Also check the quality of the mesh.
If everything is ok they you can switch Fluent Meshing to Fluent mode by GUI or TUI option.
Keyur
September 11, 2018 at 2:47 am
mashimaro_star
SubscriberHi Keyur,
Thank you for the prompt reply. Yes I can open it in Fluen Meshing. The problem is that I can read the mesh using Fluent, perform computation, then save dat and cas. However, if I close the case and want to reopen the case using Fluent, it returns the error I mentioned in the original post.
The "check" and "check the quality" reports are as follows. Could you please see if there is anything I can do? I do not want to read the mesh every time and then read the journal file to recover the case setup... Thank you very much.
Domain extents.
x-coordinate: min = -7.617500e-02, max = 7.110600e-02.
y-coordinate: min = -2.358700e-02, max = 4.558700e-02.
z-coordinate: min = -1.885470e-01, max = 1.561000e-03.
Volume statistics.
minimum volume: 1.747063e-13.
maximum volume: 2.587584e-10.
total volume: 4.123249e-05.
Face area statistics.
minimum face area: 2.478286e-09.
maximum face area: 8.736383e-07.
average face area: 1.365562e-07.
Checking number of nodes per edge.
Checking number of nodes per face.
Checking number of nodes per cell.
Checking number of faces/neighbors per cell.
Checking cell faces/neighbors.
Checking isolated cells.
Checking face handedness.
Checking periodic face pairs.
Checking face children.
Checking face zone boundary conditions.
Checking for invalid node coordinates.
Checking poly cells.
Done.
Minimum Orthogonal Quality = 3.00263e-01
(To improve Orthogonal quality , use "Inverse Orthogonal Quality",
where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
Maximum Aspect Ratio = 1.62759e+01
September 11, 2018 at 10:15 am
Ansys EmployeeHow did you transfer the mesh from Fluent Meshing to Fluent? The mesh check there looks to have passed, but I suspect the cell ID's will be different to you'll not be able read the existing data back onto the mesh.
Can you open the old case in serial on a machine? Also does the error stop you working, or can you continue?
September 11, 2018 at 1:08 pm
mashimaro_star
SubscriberThank you very much for your suggestions. Serial mode can open the old case file.
For the parallel mode, even I use the same number of processors after and before the simulation, it returns the error. The error stop me from working...
Is there anyway that I can solve this problem? Thank you very much.
September 11, 2018 at 1:57 pm
Ansys EmployeeExcellent news.
OK, open in serial then read in the data & save both with a new name. Partition to 32 nodes manually and resave both (new name again). Re-try in parallel.
I've seen it before and the above usually fixes it: it's actually possible sometimes to read into serial, save and then read into parallel but the extra step eliminates other problems. Using a different name is an additional safety step: I don't trust computers not to eat my work!
October 17, 2018 at 10:26 pm
mashimaro_star
SubscriberThank you very much! Problem solved!
2630
2104
1327
1110
461
