November 4, 2017 at 3:53 pm
simsek8
Subscriber -
November 4, 2017 at 8:02 pm
SubscriberIn DesignModeler, add new horizontal plane through the top of the narrow section. Rotate it so the Z axis points up then slice all bodies to get 5 bodies in one part. Face meshing will then give you what you want.
November 4, 2017 at 8:22 pm
simsek8
SubscriberThank you very much. I figured out except one thing. There is a pop-up message that says:
'The specified defeaturing tolerance was found to be larger than a specified size. The elements on one or more edges may be defeatured out.'
November 5, 2017 at 4:38 am
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2708
2146
1357
1150
462
