January 23, 2023 at 6:08 pm
Deniz Orta
SubscriberHello,
I want to create a subsurface model with faults, but when I am trying to create the mesh of this model in Design Modeler, I run into a problem that it does not detects faults during the "face split" stage (Even though, program sees the "tool geometry" part as 29). So, later, when I come to the "detach" part, it doesn't see the faults at all. Do you have a suggestion for this problem? Relevant images is in the attachment.
Thank you so much in advance.
Best, -
January 24, 2023 at 5:55 am
Keyur Kanade
Ansys EmployeeAre you getting error while spitting surface?
There are different ways you can split the surface. Please go through help manual for more details
Also DM is CAD tool. You can not generate mesh in DM.
Keyur
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2688
2138
1355
1136
462
