March 5, 2023 at 1:12 pm
deld
SubscriberWhen I create lattice infills for my geometries in Spaceclaim, they're generated as Facets.
I can convert the Facets to a Solid.
I'm using the Additive Prep suite to prepare the model before sending it to Workbench and Mechanical for Thermal-Structural analysis.
The thermal analysis (yet to run the structural analysis) seems to run fine for the faceted geometry.
Is there a reason why I would/should convert a geometry from faceted to solid?
March 14, 2023 at 12:20 pm
Aniket
Forum Moderatorconverting geometry facets to solid would allow you some flexibility to change mesh.
-Aniket
March 15, 2023 at 1:34 pm
deld
SubscriberThanks, Aniket. I've been creating the meshes in Mechanical but I'll have a play with Meshing in Spaceclaim and see if there's any obvious differences and/or benefits.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
