November 19, 2023 at 6:40 am
Kawshik Nath
SubscriberWhen, i want to simulate theĀ electrical properties of plasmonic solar cell in charge module, i've faced a problem. At the time, when i'm incorporating the nanoparticles or plasmonics the simulation didn't run ( adding the simulations in the absorber layer), because the nanoparticels are metal and it shows that there must be a boundary condition for the nanoparticles. But i used the boundary conditions already for the front and back contact. So, plz help me how can i solve this problem. I've attached the necessary information regarding this simulation below.
November 21, 2023 at 8:22 pm
Amrita Pati
Ansys EmployeeHi Kawshik,
CHARGE provides current/charge analysis for semiconductor materials. Metals are only applied as contacts to apply voltage to the semiconductor. So, if a metallic object doesn't have an associated BC, then this will cause an error. If you can evaluate some of the effects that you are looking for without using the gold nanoparticles, then CHARGE will be useful. Otherwise, CHARGE won't be able to simulate it.
Amrita
Computational Fluid Dynamics (CFD) helps engineers design products in which the flow of fluid components is a significant challenge. These different use cases often require large complex models to solve on a traditional workstation. Click here to join this event to learn how to leverage Ansys Fluids on the cloud, thanks to Ansys Gateway powered by AWS.Ā
Earth Rescue ā An Ansys Online Series
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3151
1680
1470
Ā© 2023 Copyright ANSYS, Inc. All rights reserved.
