November 15, 2018 at 6:46 pm
November 15, 2018 at 7:20 pm
Sandeep Medikonda
Ansys EmployeeSana, I moved this post to the Electromagnetics category. So that it might more traction.
For someone who might be able to help. Can you add some tags and mention, which software you are running this in? the procedure you are following etc?
You mention that you sometimes get an error, what is the error message? (pictures will often help).
- Maxwell, HFSS or Q3D?
- Error
2534
2066
1285
1104
459
